frankhuzzah
- Apr 18, 2007
According to Ubisoft the following are the *minimum* system requirements for Assassin's Creed
I can honestly say I'm shocked. While this game should look nice, the fact that Crysis has more relaxed requirements is crazy.
In order to play this game properly, your PC MUST meet or exceed these minimum requirements:
Supported OS: Windows XP / Vista (only)
Processor: Dual core processor 2.6 GHz Intel Pentium D or AMD Athlon 64 X2 3800+ (Intel Core 2 Duo 2.2 GHz or AMD Athlon 64 X2 4400+ or better recommended)
RAM: 2 GB (3 GB recommended)
Video Card: 256 MB DirectX 10.0compliant video card or DirectX 9.0compliant card with Shader Model 3.0 or higher (512 MB video card recommended) (see supported list)*
Sound Card: DirectX 9.0 or 10.0 compliant sound card (5.1 sound card recommended)
DirectX Version: DirectX 10.0 libraries (included on disc)
DVD-ROM: DVD-ROM dual-layer drive
Hard Drive Space: 12 GB
Peripherals Supported: Keyboard, mouse, optional controller (Xbox 360 Controller for Windows recommended)
*Supported Video Cards at Time of Release:
ATI RADEON X1300-1950 / HD 2000 / 3000 series
NVIDIA GeForce 6600-6800 / 7 / 8 / 9 series
Laptop versions of these cards may work but are NOT supported. These chipsets are the only ones that will run this game.
NOTICE: This game contains technology intended to prevent copying that may conflict with some disc and virtual drives.
