Ok, running 1009 bios on this board. (haven't tried any other versions yet). Everything is great, it's rock solid so far. BUT,
If I set my cpu (manchester 3200+) to 300*9, and set the ram divider to 133mhz - I expected my ram's (Corsair 1024mb*2, PC3200C2) actual speed to end up at 200mhz. Well no, for some reason it ends up at 192mhz ??
So I want my 8mhz! I bumped it up to 312mhz * 9, and now the ram is running at 200mhz. If I set the ram divider at 100mhz and try 300*9 - it gives me the expected ram speed of 150mhz. Anyone else experience this issue with the 133 divider? If so does the newer bios version fix it? I've run the same cpu and ram on a different board and when set to 300*9 and 133 ram divider, it correctly came out to 200mhz actual ram speed.
Second - anyone using the onboard sound? I am planning on adding a second 7800GT with large cooler (NV Silencer 5R3) down the road. I can see that it's going to be very tricky to get two of those and a sound card in between to fit. I only use headphones on this machine, so is the onboard sound really that bad compared to an Audigy 2?? With that in mind, anybody who has two video cards with larger coolers and a sound card in between want to post pictures of your setup? I'm thinking I'm going to need to mount some thin plastic protection over parts of the sound card as the mounting screws for the video card heatsink will come very close to touching it. Thanks for any images you can send me or post here...
