Carlosinfl
Loves the juice
- Sep 25, 2002
I have an Asus RT-N66U wireless N router which has been working great with DD-WRT firmware loaded on it. My problem is that for some reason no wired clients are able to obtain a working DHCP address. Wireless works fine w/ or w/o WPA2 security enabled.
I performed a factory reset on the firmware to bring everything back to default settings. I can see my DHCP is enabled and my start IP = 192.168.1.100/24 & my DHCP offers up 20 leased addresses.
I've even statically set the IP on my workstation to a valid / available IP address & still can't route out. I've swapped Ethernet cables and changed LAN ports on the N66U.
Any suggestions?
Any suggestions?
