I recently swapped out motherboards. I went from a Biostar TP45HP to an Asus P5E. On the Biostar I was overclocked to 3.4ghz on my Q6600 with speedstep enabled. With this set up, when my cpu was idle both the multiplier and voltage would drop. This was pretty nice as my voltage wasn't at 1.45 allll the time.
With my new setup on the Asus P5E I'm also running 3.4ghz with speedstep. However, when speedstep kicks in when the cpu goes idle...the multiplier drops but the voltage does not budge. This is pretty annoying. Using less energy when it isnt needed is always good and preferred.
I have speedstep and C1E enabled. Do Asus motherboards override voltage change in speedstep when the FSB is manually set?
