After weeks of tweaking and Orthos stress testing, I think I've found my perfect sweetspot for my P5K-Dlx + E6700 combo.
Please feel free to use my OC BIOS configuration below for reference purposes.
I'd like to also give out my special thanks to EVA2000 and numerous other members who gave out their generous tips and pointers.
This is what makes the whole OC community so great:up:
JumperFree Configuration Settings
AI Overclocking: Manual
CPU Ratio Control: Manual
- Ratio CMOS Setting: 8
FSB Strap to Northbridge: AUTO
FSB Frequency: 466
PCI-E Frequency: 105
DRAM Frequency: DDR2-1166
DRAM Command Rate: 2T
DRAM Timing Control: Manual
CAS# Latency: 5
RAS# to CAS# Delay: 5
RAS# Precharge: 4
RAS# Activate to Precharge: 5
TWR: 3
TRFC: 30
TWTR: 3
TRRD: 3
TRTP: 5
DRAM Static Read Control: ENABLE
Transaction Booster: AUTO
Boost Level: (only displays when Transaction Booster is set to Disable or Enabled)
Clock Over-Charging Mode: AUTO
CPU Spread Spectrum: Disabled
PCIE Spread Spectrum: Disabled
CPU Voltage: 1.4500
CPU Voltage Reference: x0.63
CPU Voltage Damper: Enabled
CPU PLL Voltage: 1.7
DRAM Voltage: 2.2
FSB Termination Voltage: 1.40
North Bridge Voltage: 1.55
North Bridge Voltage Reference: x0.61
South Bridge Voltage: 1.2
Advance CPU Settings
C1E Suppport: Disabaled
Max CPUID Value Limit: Disabaled
Vanderpool Technology: Disabaled
CPU TM Function: Disabaled
Execute Disable Bit: Enabled
PECI: Enabled
USB Configuration
USB Functions: Enabled
Legacy USB Support: Disabled (need to enable it to detect USB flash drives)
