I know these boards are notoriously slow at booting but I've also heard from a couple of forummers that my time is particularly bad. It basically takes ~15s before the monitor even turns on, then ~10s performing the POST, followed by a ~15s Windows boot from my SSD, in a best case scenario. I just wanna know if anyone here has any experience or suggestions for trying to reduce POST time on this or other P6T boards? Below is a list of all of the things I have currently done in an effort to reduce POST time.
The only other thing I can think of is to just set it to optimised default and re-do my overclocking but that's a bit of a hassle and I don't think it'd make any difference. It's just really depressing to have a fast Windows boot time but still have to wait 40-45s to use the PC, which is what most people can get with a normal HDD anyway.
Any ideas will be appreciated dudes. Thanks.
- Turn on "Quick Boot".
- Disable "Full Screen Logo".
- Disable "Express Gate".
- Set first boot priority to SSD.
- Disable unused hardware (floppy disk, second ethernet port, Marvell storage controller, firewire).
- Disable "Legacy USB" so that external HDDs aren't powered on and then off again during POST.
- Set "Add-On ROM Display Mode" to "Keep Current".
- Turn off auto-detection for empty SATA port (other 5 are full).
- Disable monitoring of fan speeds and voltages (left temperatures on just in case).
- Reduced the IDE timeout to 0s.
- Set DRAM timings manually (they were actually set to 9-9-9-27 and should have been 8-8-8-24).
- Set "Plug and Play OS" to "Yes".
- Unplug my memory card reader (I've read that these can cause boot problems).
