I built my new system last week, and it booted up no problem. I worked my way up to 4.7ghz at 1.35v and ran prime and LinX tests for a couple of hours. I moved on to 4.8ghz at the same voltage and booted windows fine, but failed stress tests after a few minutes, so had to power down and then reboot. This is where it gets interesting. I couldn't reboot at anything over 4.4ghz. I removed the battery, did everything I could think of in the bios and no luck. Then when I did something simple like change VCCSA back from .950v to auto, it started to work (trust me, that's not the fix..just happened that one time). I was set again...I tweaked up the voltage to 1.350v and ran tests for hours at 4.8ghz without problems. Then I went to 1.375v and booted at 4.9ghz, but only ran a few minutes of tests, then tried booting at 5.0ghz...lockup and had to power down, and then I was back to not being able to boot above 4.4. After an hour of screwing around again, clearing cmos, etc. something magic happened and I was back in business above 4.4 again.
After awhile I decided to not wait until I locked up again through pushing stress testing and higher frequencies, so I was just running at 4.5ghz, and did a shutdown from windows to see what happens. I powered back up and hung at the windows screen again. I powered up and down a few more times and suddenly I booted ok at 4.5ghz and I was above the "wall" again. I did a windows shutdown again and once more hit the 4.4ghz wall. I haven't gotten back to 4.5ghz and above yet, so I'll probably remove the battery again and screw around again until I "luck" out again and break past the wall again..then I'll be good until I power down again. I've done this enough times to know that eventually by some "random" quirk I'll break through 4.4ghz, and then I'll be fine until another power down. By the way, once it's working I can reboot from windows, tweak stuff in the bios, and things are still fine until a power down. "JJ" or someone else from Asus, can you pass this on to the bios team? Any ideas?
Update: Trust me, I've played around with the "Internal PLL Overvoltage" setting a lot with trying to consistently boot above 4.4. When I'd made this original post I'd temporarily given up on breaking through 4.4ghz, and was running 4.4 and "Internal PLL Overvoltage" on auto. I decided to work on the issue again, rebooted to the bios, set "Internall PLL Overvoltage" to enabled and multiplier to X45 and magically I'm above 4.4ghz again. As I said, I've played around with "Internal PLL Overvoltage" a lot before, so I'm sure I haven't found the magic cure this time, since I've done it all before. Is there a chance that "Internal PLL Overvoltage" is getting set erratically or something? As soon as I have to power down for some reason, I'll likely be back to fighting the problem again. I've gone through this whole cycle like 6-7 times now.
