I finally got around to doing my Microcenter swap out yesterday and decided to upgrade from the Pro to the Sabertooth. My Pro had been pretty reliable, but I need access to all my SATA ports, so as big a PITA as it was I took it apart and hauled it in.
Now I've got everything put back together and have two absolutely huge problems with the Sabertooth and one minor issue.
I'm currently running everything at stock. 2600K, H50 cooler, 16GB Corsair Dominator, OCZ Vertex 120GB SSD as boot drive, XFX Radeon 5950 for video. The board is running the current 1502 BIOS.
1) It literally takes over a minute from applying power until the POST actually starts. Until then, I'm just staring at a black screen. Is this normal for this board? The P67 pro was very slow to start up, but this is much worse. Any suggestions?
2) Sleep mode is not reliable at all. The P67 pro was the first high end board I could actually use sleep mode without issues, but I have not once successfully resumed from sleep on the Sabertooth.
3) The more minor issue, the computer will not finish booting if my UPS is plugged into to the USB port. It will POST, but then hang with a flashing cursor before loading the OS. If I unplug the UPS and reboot, I have no issue getting into Windows.
If anyone has any ideas or helpful hints, I'd appreciate it.
