OK, hear me out on this for a moment. I've picked up a HIS ATI HD4890 card to do a last ditch effort to stretch the life of my Shuttle SN25P wAMD x2 [email protected]. I also couldn't resist the NewEgg deal that was on here recently. Now I know I'm CPU limited, and I'm nuts by trying this, but that's what [H] is all about and I'm too broke to build a new QuadCore.
Need to know:
Running HD4890 w/ External PSU hooked up with 4 Molex leads feeding the card.
The PSU is a Antec True 480W unit with 12V rail rated at 22A
Used above since I was afraid to melt Shuttle PSU, they're tough, but not this tough.
Running 1680x1050 res, gaming at 2xAA or 4xAA
So here goes my problem:
Within several minutes to an hour, screen goes black, game sounds either continue, and or get stuck in a loop. ATI VPU recovery kicked in once, just once.
First occurence, ran the Street Figher IV benchmark. Tried over and over to see how high I could get in FPS @ Native res, got to 220, Ryu did a special move, and poof, screen went black, sound in loop/continuing.
Reset machine, the card goes in a loop, Fan On/Off/On/Off with 3 Red LEDs on side flashing each time. I shut power off to everything, give it a second, power up, system boots fine.
Load up Folding@Home GPU GUI Client, instant screen shut down, VPU recover kicked in.
Here's something I gotta check again, I swear on the last crash, my Antec PSU was dead, fans off, I wasn't sure since I shut everything down pretty quickly. I'll recheck this, but at the moment, card won't crash for over and hour playing COD5 Zombie mode.
This brings me to the last part and screen cap below. This is GPU-Z 0.3.4. I'm not 100% positive, but doesn't the HD4890 take about 180W+ @ Max Load? ( I may be way off )
Why is the VDDC Amperage @ 42A
Why is the other Amperage @ 18.5A (presume 12V = 220W)
edit: Last update, above screen, Folding@Home GPU running. Just noticed, Anted PSU squeeling, it's not vid card, it's PSU. Is the Antec being overloaded, is there a problem with my card? 22A @ 12V should be enough to power a Vid Card if my above wattage estimate is correct. Amperage at idle, while typing this, 1.4A to 4.1A.
Need to know:
