More info on ATI multi-rendering, don't think there's much new here but so close to the predicted launch the likelyhood of accuracy gets that much stronger with each retelling.
If this works the way it sounds (obviously a big "if") then SLI is getting some serious competiton.
MVP (apparently the latest name for it) would seem to be both more flexible and more scalable than SLI with a cheaper upgrade path, you don't need matched cards, and ANY existing ATI pci-e card, apparently from x700 up anyways (including onboard), can do secondary/slave duty.
MVP primary card functionality may start at the x850, and not require a next gen card at all.
Nvidia is going to want to have a pretty good answer to this.
