blacklotus
- Apr 26, 2006
Which brand should i go with when deciding my next card? From my readings in this forum, the Nvidias have better drivers and better scaling than the ATIs for larger monitors; is this true?
blacklotus said:Which brand should i go with when deciding my next card? From my readings in this forum, the Nvidias have better drivers and better scaling than the ATIs for larger monitors; is this true?
Shocky said:At 1920*1200 you want SLI or crossfire, with a X1900XTX or 7900GTX your going to be dropping details and in allot of games you will have to loose AA to keep performance up...
QFTShocky said:At 1920*1200 you want SLI or crossfire, with a X1900XTX or 7900GTX your going to be dropping details and in allot of games you will have to loose AA to keep performance up...
You can wait for the X1950XTX but at the end of the day its just a X1900XTX with faster memory so it remains to be seen if it can compete with multi gpu solutions.
spade357 said:Im sure a single 7900GTX/X1900XTX is sufficient enough to enjoy my games with a "24 monitor. I don't think it will affect me that much playing my games at 90% details. Now back to the original post; i heard ATI cards don't have scaling settings and that the drivers are buggy.
spade357 said:ATI cards don't have scaling settings
xenogears said:The 2407 has scaling options on the monitor, so it doesn't need to do it from the drivers.
Shocky said:imo, no its not... I upgrading from an X1900XTX on my main rig because the performance wasnt good enough for me, I don't like playing without AA and dropping ingame settings.. X1900XTX is now in my other rig which only has a 19" so its limited to 1280*1024 which it can handle pretty well.
