Mansize_tissue
- Jan 1, 2007
I'm thinking of replacing the two front satellites of my Z-5500 set with a pair of bookshelf speakers; is this possible?
Yep.
it works fine if you dont listen super loud. i used some cheap pioneer speakers on my z680 till i decided to blow the logitec amp up a little.
this is right after i blew the amp up, which was followed by by the cheap onkyo.
in the end not a great difference in sound but a difference none the less. the top end is loads better but teh cross over is set hi (well over 100zh) so it still sounds a bit thin.
I also replaced my 2 front sats with Polk R15, and the diff is pretty big for me. But I'm looking for a good cheap center channel to replace the log one... which one do you have?
Did you replace the satellites on a set of Z-5500s with these?
This is a first step to moving up to a receiver based system.
I would wholeheartedly suggest that you do this for now, and save money and get yourself a receiver based system at a later date. The sats on the 5500 are not exactly its strong point. The 5500's strongpoint is its versatility... but by adding better fronts mains to it, you'll definitely improve your music experience in stereo and by carefully balancing the overall volume for all 5 speakers, you can improve your movie watching/gaming experience as well.
As long as your speakers are not a tough load (say 4ohm impedance), you should be ok.
Though wattage ratings should always be taken with a grain of salt, a set of 80watt speakers should be perfectly fine. Distortion will probably keep you from maxing the volume anyway.SJetski71, if I get a pair of speakers rated at say 80 watts, there wouldn't be any chance in anything blowing would there? I mean, the amplifier won't be able to handle this much anyway so it won't overload them, I don't think.
Computer speakers like the Logitechs and Klipschs are 6 ohm. Most bookshelfs for *real* audio systems are usually 8 ohm. Translation: volume level won't be quite as high, which would be not be a problem in your case. Like one of the earlier posts, distortion would win out over volume at the higher levels.
Decent A/V and audio receivers will drive 4 ohm speakers. I doubt the z-5500's would. Less resistance = higher amps, which would not be good "cheaper" amps.
In the end, your bookshelfs should be just fine.
this is what i meant with "the top end is loads better but the cross over is set hi (well over 100zh) so it still sounds a bit thin" the amp is crossed over at 120kz 'ish and all the sound under that point will route to the sub. there is no way around this but for me the 680's where for gaming only so i did not mind. voices in movies will sound "chesty" because the sub will put far more power in the high bass freq. then naturally produced by our body. with a bookshelf containing a tweeter you are only gaining higher extension and maybe a bit of clarity but the mid performance will remain the same.One thing I've noticed, though, is that I notice a lot more sounds in my music, such as symbols. However, the mid-bass isn't really much better
Any advice with respect to the question in my previous post? I want to try out these speakers to see if there's any improvement. However, I don't know if their lower impedance and higher wattage will cause any damage to anything.
5500's sats are 6 ohm. Higher wattage (if I understand correctly) simply referances how much power the speakers can handle. 60 watts should be fine. OR... If the speakers begin to sound distorted, turn the volume down.
they would not play as loud for a given volume at the same sensitivity.
No No No, 4ohm speakers have less resistance just like headphones, but this also means they will pull more current from the amplifier, which may not be able to handle it.
Basicaly if you put 2 8 ohm speakers in parallel you will achieve a 4 ohm load, which may or may not cook the amp (pulling twice the current from the same channel on the amp).
