jamesman32
- Jan 11, 2009
I currently have a home audio setup that runs as follows. I have a Sound Blaster Z running optical audio to an Onkyo receiver. I have a pair of 7870s in crossfire, one of which is using HDMI through the Onkyo receiver into my monitor. My issue is the following; every few moments, my audio cuts in and out. It happens a few times every song in iTunes, once in a while in Pandora, every so often on Youtube, etc, and it even causes my in-game sound to get really distorted. The computer responds, but the sound just drops momentarily.
Here's what I've done so far to try to troubleshoot.
- Reinstalled Windows (Didn't help)
- Updated BIOS (Didn't help)
- Updated audio drivers to newest version (Didn't help)
- Tried beta audio drivers (Didn't help)
- Disabled all audio playback other than optical (Didn't help)
- Updated GPU drivers (Didn't help)
- Uninstalled HDMI audio drivers for GPU (Didn't help)
- Tried beta GPU drivers (Didn't help)
- Tried connected HDMI straight to monitor with no receiver pass (Didn't help)
- Connected headphones directly to sound card and disconnected optical (Works, no drop out!)***
- Connected headphones to receiver, connected receiver to soundcard with optical (Didn't help)
- Set PCIe slot to manually default to Gen3 in BIOS (Didn't help)
I've researched this issue a bit more, and I've found that MANY people have had weird HDMI audio dropout issues with the HD7000 series (very similar to mine), but I'm not using HDMI audio through my GPUs, I'm using optical from my Sound Blaster Z. There is a known registry fix for this bug, which I've tried, and it does not help my issue either. The only "fix" I have found is disconnected optical completely and plugging my headphones into the 3.5mm output on the sound card, meaning my receiver and speakers are useless.
For reference, the SB Z and Onkyo receiver worked fine together in my previous rig. The only "new" components in my system are the 1150 MB and CPU, and the two 7870s. Previously I was on 1155 with a single GTX670.
Any ideas?
Any ideas?
