Ok so I've been using an Auzentech Prelude 7.1 PCI sound card for about a year now with headphones. I had them connected with the basic line out port on the back of the card but now that port has gotten loose so the sound cuts in and out at times. Now I'm trying to just use the front panel header and connect to the port at the front of my case but I have a few questions.
1) Is there any sound quality loss when using a front panel connection FP HD audio or AC97
2) What's the difference between AC97 and HD audio. Is HD audio back wards compatible with AC97?
3) Does my sound card support FP HD audio. The auzentech site says it just supports AC97 FP audio but I'm using a HD audio connector right now and there doesn't seem to be any issue.
