StrongBadia
- Apr 2, 2003
I first got my NV5 Silencer last week. When I installed it, I applied thermal compound like I would on a cpu (ie. a very thin layer spread out with a razor). It dropped my temps a couple degrees, but didn't help much with the oc'ing. I could only get 390/1100 at 1.3v. I flashed to 1.4v and could get to about 400/1100.
Ambient = 35C
Idle = 59C
Load = 80C
So, I got bored today and reseated my NV5 and added quite a bit of AS Ceramique to the memory and core. I added about a small pea size drop to the memory and a little larger drop on the core. My temps dropped SIGNIFICANTLY. Unfortunately, one of the screws snapped off with a bit of the thread stuck inside while I was tightening the NV5 down. Thankfully, it's on a side where I don't think it will matter (The bottom right one by the molex connector). The screws are VERY fragile, so be careful.
My new temps (Keep in mind, these are WITH my 1.4 volt mod):
34C Ambient
48C Idle
61C Load
Awesome!
My new clocks.... *Drum Roll*
450/1.18
Try and tell me that isn't worth the $25 I paid on ebay.
Ambient = 35C
Idle = 59C
Load = 80C
34C Ambient
48C Idle
61C Load
Awesome!
450/1.18
