superkdogg
- Oct 14, 2004
Hey, this is another one of those "Which one should I use" threads, so if those make you have a seizure or otherwise annoy you, please look away.
I have had an x850xt PE for a long, long time now (flashed GTO^2). It has an aftermarket cooler on it and clocks about 10-15% higher than the stock PE speeds.
I recently was looking for a cheap card that will play some games and came across the now-finished deal on Newegg for an Asus 2600xt that cost $28 after shipping and rebate.
The 2600xt doesn't appear to OC that well.
The rest of the rig in question is a A8N-Sli (the one with two x16 lanes) and an Opteron 144 that clocks about 2.8 or so with 1.5 GB of DDR400.
I won't be using any of the HTPC capabilities like the HDMI out with sound or any of that, nor hardware decoding, etc. This rig is just for cheap gaming.
It looks like the cards offer pretty similar performance, with the biggest difference being that one card is DX10-capable (but not really 'capable') and the other is DX8.1 or whatever and not even true DX9.
The way I'm looking at it, a DX10 game would probably cause me to adjust the settings down a ton on the 2600xt so that it might as well be running old shader paths, and the x850xt has more power.
Basically, in a nutshell--Is it stupid to choose the 4-year-old card over the 1-year-old card for any reason?
