As I said over in the "Benchmarking a myth"-thread, I've been planning to benchmark 2003 against XP for gaming and other frivolous uses. I've now got everything up, and I've got some results.
The hardware:
Asus PP-DLW
Intel P4 Xeon 2.8 (HT enabled)
1Gb PC2700 DDR Ram
Radeon 9800 Pro , 128Mb VRAM
Promise TX2+ SATA-controller
2x 250Gb Maxtor MaxLine SATA HDs
The software:
Windows 2003 Server, Standard (SP1 and all updates)
Windows XP Professional (SP2 and all updates)
The same drivers, as far as possible
CS : Source
The method:
I installed each windows on it's own HD, in a 100Gb partition.
In XP, I disabled the theme, but otherwise left it alone.
In 2003 I changed the performance settings to favor foreground applications, and set Hardware Acceleration to max in the graphics settings.
After installing everything I rebooted, ran three video stress tests (at the default settings), rebooted, repeated, rebooted, repeated, giving a total of 9 runs for each OS. The results were fairly consistent through all the tests on both OSes.
The results:
This is the average over all nine runs.
XP: 90.07 fps
2003:: 88.27 fps
The conclusion:
XP is the faster OS for this particular benchmark, as expected. However, the difference is not by any means big. From what data I've got so far, it looks like 2003 will be a perfectly good OS for gaming if one for some reason wants to use it for that.
As for the practicalities: 2003 took a bit longer to set up, mainly because SP1 is huge. The two minimal tweaks I did took less time than setting a sensible default directory view in XP, so my hands-on time before I considered the install finished was roughly identical. I didn't do anything else to 2003 that I didn't also do to XP.
Also, a random piece of advice: Don't install windows with a CF reader in an USB port. I have a 7in1-reader and an install of Windows 2003 Server that resides on I:\ . (I know, it should have been J:\. Wonder where the last letter went.)
What now?
The disks are both going to be moved to the BSD-box and reformatted as UFS2 in a few days, but until then, I'd like to run a few more benchmarks. Suggestions are welcome, especially ones that would be easy to aquire and run.
The hardware:
Asus PP-DLW
1Gb PC2700 DDR Ram
The software:
CS : Source
The method:
The results:
XP: 90.07 fps
2003:: 88.27 fps
The conclusion:
What now?
