verylostindeed
- Dec 27, 2004
Anyone know if the BenQ G2400W has 1:1 pixel mapping? Thanks a ton.
Display Mode
(Display model)
This feature provides the outside 16:10
Not in proportion to the original geometric distortion
Status Display.
Overscan ─ losers slightly enlarge
All images. If the image around
Noise disturbance, so that
Using this feature hidden noise.
Full (full-screen) - Full -
Show Input video screen ratio
Like. Is the ratio 16:10
The best image display.
Aspect (the original ratio) - losers
No images of the geometric distortion
State, and to the extent possible release
The big screen. 16:9 image water
- Filled screen, and 4:3 video
Like to fill the screen vertically.
1:1 - to the original resolution was
Show input image, not change
Showing ratio.
Press the "ENTER" button to select
This option. 􀁗 or 􀁘 again?
Bond set changes.
In accordance with the input signal sources may be,
"Display Mode (Display Mode
-) "Will have the option under
Different.
When the signal sources
DVI or D-sub,
And the input image for
Non-widescreen ratio
When:
Full (full-screen)
Aspect
(The original ratio)
1:1
Or
HDMI pm:
Overscan
Full (full-screen)
Aspect
1:1
