Best 32" 2560x1440 gaming monitor?
Motley
Ok so right now I have a two year old Samsung S32D850T . I like it, but I want a better refresh rate, this Samsung is only 60hz.
Also would like an IPS panel.
Budget is around $600-$800
I appreciate any suggestions...
No need to spend that much, the HP Omen is you're best bet at that size. 75hz with freesync.
If you want to go 34" ultrawide 3440*1440, there are a couple options that do 100hz for around 700-800. Microboard and crossover both make good ones.
Maybe nVidia HDR monitors in the Q2-Q3 might be available in that size. Expect $1200.
just wait till may/june. then there will be 32" wqhd va 144hz panels on the market. i read aoc is producing one but i think this will not be the only one with this specs
