Hi all,
About 8 months ago I decided to watercool my rig during a mid-life upgrade to a quad core and a better motherboard. I settled on a single loop cooling the CPU, comprising of a Swiftech MCR-320, Liang Li DDR 3.2 pump, Swiftech MicroRES, and a D-Tek Fuzion. The rest of my current rig is expressed in my Sig.
All of this is currently housed in a TJ-09, except for the radiator which is mounted on the back. Originally I had wanted to mod the TJ-09 to fit the 320 across the top, but after careful study, I decided it would be too much of a hassle. (The chief issue is that I live in an apartment in Manhattan w/o easy access to a workspace in which I can do the necessary dremel work.)
My current setup with the RadBox works, but it's clunky, and it really doesn't fit under my desk anymore, so basically, I'm looking to upgrade my case. I love the Silverstone's build quality and layout, but I need something that can fit the radiator inside without modification work. My search has brought me to basically two options, the Lian-Li PC-A77 and the new V2100/V2110, as these a) look to be able to accommodate my hardware, b) have breakout USB ports at the top vs bottom (very important,) and c) conform to a classic full tower profile. Does anyone know if these can accommodate the MCR without modding?
Note that I researched the TJ-07 when building my rig a year and a half ago, and decided to pass on it due to complaints about airflow around the video cards and side rattle. However, besides the two Lian-Li's, I'm pretty much in the dark about what's out there that will fit my setup (with radiator) internally. Any help and advice would be appreciated.
Many thanks!
Many thanks!
