you wont notice any difference in IQ between a properly working DVI-D cable and a sell-your-child-to-afford priced Monster DVI-D cable at all. the only difference is that the Monster is "better shielded from interference" than the stock cable. its all just marketing gimmicks to steal your hard earned money. Same thing can be said about their speaker wires and av cables. unless you are dealing with very high end aka expensive home theatre stuff, none of this stuff will EVER make a difference.
Better to say that, for digital signals, the difference is non-existent. It either works or doesn't. The only difference a higher quality cable could possibly make is to increase the distance the signal can travel.but anyways thanks for the notice that for display,the notice is too small and negligible.
For digital it doesn't make a difference...but with analog it does. For analog video connections I've seen better results with higher quality cables.Same thing can be said about their speaker wires and av cables. unless you are dealing with very high end aka expensive home theatre stuff, none of this stuff will EVER make a difference.
