I have a 500GB external drive (actually a WD internal drive in a caddy) in a single partition. A few days ago I tried to resize the partition on it to give me a fresh 5GB partition at the beginning so I could use it to install Windows when my new PC arrived. About 70% of the way through the "moving data" stage (after around 10 hours), I got a "read error" from EaseUS Partition Master. It told me to reboot, I did, and now the drive is corrupt.
I've used Power Data Recovery to restore some of the data but a lot of random audio and video files do not work. All of my important data is fine so I'm not too bothered but I've tried two different methods - the first is "advanced recovery", which I assume scans any bits of MFT it can find. This found all of my important documents as I said above but otherwise it did not find much else. The second, "deep scan" (which I assume scans the actual HDD instead of the MFT, which is obviously badly corrupt in my case) took around 8 hours to complete but it restored many files that the other method failed to recover. The only problem with this mode is that it's restricted to certain file types (for example, I've got all of my MP3 and WMA Lossless files but it cannot detect any MKV or MP4 video files).
So, my question: is there any other similar software package that can find a bigger array of different file types using a "deep scan" method?
Thanks for any suggestions.
