What's the best orientation for vertically fitting a motherboard? If you had the choice from either cpu and ram up top, gpu's bottom or gpu's up top and cpu and ram at the bottom. This is in regards to heat (forget about fans for a second as the cpu and gpu's will have waterblocks fitted and the motherboard has no heat pipe technology).
Can you explain your reasoning when you give your choice, cheers!
