My house has ground-source heat and a hot water pre-heater built into the refrigeration unit. This system will dump heat from the AC system into a water loop from my hot-water heater, thus during the summer cooling season, I get some free hot water. Eventually I want to install a tankless on-demand water heater and use the current 40 gallon tank heater as a pre-heated storage tank.
This is where the CPU water cooling comes in. The copper lines running from the water heater to the heat pump unit pass directly under my office in the crawl space. I would like to cut into the cold side of that loop and cool my computer water loop with the cold water from the bottom of the pre-heat storage tank. This loop has a ~10W AC pump which is controlled by the heat pump, but I can cut into the wiring and control it myself as well as letting the heat pump turn it on.
I will have high-pressure(50-75 psi) water which I can control the flow of that should maintain temps of 50-90 Fahrenheit depending on the season, hot water use, etc. I have 2 options so far for transferring heat from the WC loop to the high-pressure water.
Option 1: Fish tank as a reservoir. high-pressure water runs through a car AC evaporator or condenser which is submerged in the fish tank. This has the benefit of simplicity and serves as my reservoir, but is bulky and prone to water evaporation and contamination.
Option 2: coiled annular tube heat exchanger. These are used in many of the heat pumps to transfer heat between 2 fluids. Basically its a copper tube inside a larger copper tube which is then sealed and coiled so that the 2 fluids are on either side of the inner copper tube wall but cannot mix. The keeps the system smaller. Most likely the exchanger will be the only thing outside the PC case.
http://sentry-equip.com/Products/dual-tube-coil-heat-exchanger.htm
Other options are welcome or observations about the ones I have here. I think during winter I can probably get some nice overclocks by pulling 50F water from the ground pipes, but the main goal here is to harvest the heat from my PC to get free hot water.
