Well, what is the best way?
We saw in the recent [H] X1800XT article, discussion on temperatures. However, the review team noted inconsistencies that made readily comparable temperature measurements difficult.
I'd like to make a suggestion on what is in my judgement a better method ... measuring power consumption. The card as a whole cannot dissipate current it doesn't draw. The team at StorageReview came to similar conclusions on hard drive heat - they measured top plate temperatures, but they found that the results were hard to make consistent and repeatable, even though the measures were easier to take.
Admittedly there are some obstacles to this. One is the impact of RAM on power usage, however that can be readily measured by measuring, for example a 256MB X800XL and comparing it to a 512MB X800XL. All other things being equal, the extra power consumption can be safely presumed to come from the extra RAM. Once a large database of power consumption figures is built, it becomes fairly easy to judge the cooling requirements of a card based on its power consumption. Thoughts?
