Purchased from Compusa for $279 with a $30MIR ($249)
Configuration:
Lian Li V1000B
BFG 680i
C2D 6400 w/Zalman 9500
8800GTX
2GB Corsair 8500C5
X-fi
Enermax Liberty 620W PSU
(2) 72gb Raptors (Raid0)
NEC DVD/RW 3540A
The bad:
My first issue started when there was no floppy included with raid drivers to load with Windows install (F6) and I could not locate the drivers anywhere on-line! I finally decided to install on a spare 160gb drive and just re-do the install once I could locate the drivers to put on a floppy....(I know they come with the eVGA 680i MB)
Next I had issues with frequent BSOD and lockups that turned out to be caused by BIOS auto setting the memory voltage to 1.85V instead of 2.2V. (I am using 2x1024 Corsair 8500C5). I believe the included BIOS on my board may be 17??
My final gripe is that I am unable to control the CPU fan speed via BIOS settings or NTUNE. CPU fan is always 100% regardless of BIOS settings using manual or smart fan and the NTUNE options for direct control are greyed out. Anyone else have this working with their 680i - if so what BIOS version MB?
The good:
I was able to easily overclock this board to a modest 2.8ghz with no issues. I did not try pushing it any higher until I have time to read up on the overclocking "best practices" for this board
My 8800GTX screams with the mild CPU overclock - after running the 8800GTX on my previous AMD platforms I was definitely very CPU limited! I was able to easily surpass my old 7900GTX SLI scores from my C2D E6600 P5N32-SLI SE setup.
3DMark06 = 10516
3DMark05= 16003
I had to do some minor dremelling on my Zalman CPU bracket to clear some of the components on the back side of the motherboard, but the 9500 is working great with just enough clearance from the case bottom to fit.
The 680i seems to work fine so far inverted in my V1000B. NOTE: I had issues with my previous P5N32-SLI SE Deluxe inverted as it would not boot after it got warm. (I had to install extra fans to cool the NB / SB heat pipes.)
Interesting note that the Motherboard manufacturer is reported as eVGA NF-68 in CPUZ
I contacted BFG Tech support about my issues and they pointed me to a PDF on the driver CD for instructions on the RAID.The tech also let me know BFG is supposed to be meeting with NVIDIA later today and would discuss my BIOS concerns for fan control and get back to me.
Configuration:
Lian Li V1000B
BFG 680i
8800GTX
2GB Corsair 8500C5
X-fi
NEC DVD/RW 3540A
The bad:
The good:
3DMark06 = 10516
3DMark05= 16003
