GnatGoSplat
- Sep 12, 2007
I just got a BFG 7900GS OC card from Frys. It is stock overclocked to 540MHz (normal is 450MHz). My machine intermittently locks up when I play videos!
My hardware:
Gigabyte GA-MA69G-S3H motherboard (AMD 690G chipset).
AMD X2 4400+ 2.3GHz (no OC).
HP 4GB DDR2-667 oc'd to 800 5-5-5-15 (Micron D9HNL).
Ultra X-Finity v2 600W PSU
Seagate 320GB SATA HD
Running Vista Ultimate x86 32-bit
Using latest nVidia drivers v162.22.
With the new 7900GS, my machine locks up when I play any videos. I tried playing 1080i HDTV (DVR-MS file) in Media Center. It locks up. I tried WMV and MPG in Media Player. Locks up. It can take anywhere from 5 to 40 minutes to lock up, but always within an hour. When it locks up, the image is frozen on screen with no visible corruption. About a half second of the sound is repeating over an over. I have to press and hold the power button to shut off the computer. The desktop and 3D games are fine!!! I only have problems with videos!
Everything was fine before when I had a GeForce 7300GS video card and also when I was using the onboard X1250 IGP.
Here is what I have tried:
1. It was using FFDShow decoder, so I uninstalled it. Then it was using Cyberlink PowerDVD decoder. Still locks up. So I uninstalled that. Now it's using Microsoft Vista MPEG2 decoders. Still locks up. Must not be decoders.
2. I ran Gigabyte EasyTune5 health monitor. All voltages looked fine. The lowest the 12V rail ever got to is 11.98V. I don't think it's the PSU. When it locks up, the screen freezes and at the moment it froze, I can see the voltages looked fine.
3. Suspecting maybe the northbridge was overheating since the larger card might block more air than the smaller 7300GS, I monitored NB temps which got up to 49C when it used to be 44C, so larger card did block a little air. I put a small fan pointing at the NB heatsink and it stayed 38C the whole time. Still locked up. Nope, guess it's overheating.
4. I know the CPU wasn't overheating, it peaked at about 47C. Not the CPU.
5. RAM has been fine for months at DDR2-800, but maybe it went bad. So I ran MEMTEST86 overnight (and still running). All passes, no fails. Not the RAM.
6. Suspecting maybe the video card is bad, I installed nTune and downclocked the card from 540MHz to 450MHz, then played a video. Still locked up!
7. I ran nTune's Stability stress test and checked everything and let it run for an hour. Everything was fine! I then unchecked everything except PCIe and GPU and ran it for another hour. They tested fine! GPU temp never exceeded 60C.
8. I have a 2nd machine (running Intel C2D) that has this exact same video card. I switch the cards, putting the newer one into the Intel box and the older one in the problem machine. The Intel box is fine, plays videos 3-hours straight with no problems. After about 40-minutes of playing a video, this machine locks up with the older, but identical 7900GS card. So that proves the video card is not defective.
I have ruled out decoder, NB, CPU, RAM, PSU, and video card. Both machines are running Vista Ultimate 32-bit and both are using the same 162.22 drivers so I don't think it's a driver issue.
One thing I forgot to do is pull an old dialup modem, which I will try when I get home from work, but I'm not expecting that to be the problem. Other than that, I don't know what else to try. Any ideas?
My hardware:
