Cool I'll check it out. I'll also try to check out whether or not its the other components.
I have two Antec Tri-Cool Fans, Seasonic M-12 600W psu, and a AC Freezer 7 pro in an Antec 180p.
Could the noise be coming from one of these components...? I just assumed it was coming from the video card as it is so huge. From what I can tell, that is where the noise is coming from.
Is there a way to control the rpm on the freezer 7 to see if that is the issue?
The rather primitive method I use is to stick a finger or something into the questionable fan on startup, so it doesn't spin. Easy for me (no danger of overheating in the <15 seconds it'll take for you to check noise).
Ok, well I doubt it's the 8800 then. Something else is making that noise. Because the 8800 is very quiet.
What motherboard? The fan is probably being run at 12v, where it doesn't need to be.
Asus Qfan runs mine at around 8v.
just thought Id chime in.
I grabed the BFG 8800GTS 320mb factory OCed and its so quiet, I keep checking to see if the fan is on.
