Hello i was going to cut some blow holes to mount some fans and the mount the radiator to the fans, 120mm fans. I wasnt thinking and picked up a 4 3/4in hole saw. basically 121mm. Is this circle going to be too big for the fan? meaning if i cut it will the mounting holes to mount the fan be cut out as well? thanks
