word.Hard911 said:very easy
electric drill and holesaw and it takes 30 sec ~ 1 min
no experience needed but at least need to know how to use a drill
dtess17 said:is this stuff needed?
http://www.frozencpu.com/mol-01.html
also what size drill bit for the screw holes?
Darkala said:That depends on how nicely you would like to sand the hole. The molding gets you out of de burring the hole completely. otherwise you will have to sand or file the hole smooth.
