Borgschulze
- Feb 28, 2005
So I did it, drove over to Canada Computers on Dundurn St, walked in and demanded an Antec P180B
It's MUCH lighter than my Chieftec Matrix series case, and way better looking.
I'm not going to put my parts in it yet though, I'm waiting for a Swiftech MCP655 to go along with it.
Also, today I recieved my tubing from Performance-PCs... they sent me the wrong tubing
Why the big smile? I ordered Clearflex60... they sent me... Tygon R-3603! Man, this tubing rocks and I haven't even got it wet yet. It's so soft and rubbery, I feel I have disgraced watercooling by using the cheap tubing I have now.
My question/request though, is if anyone with this case and a radiator attached to the rear 120mm fan bracket, if they could post pictures of how far the rad hangs down and the clearance between the DVI cable and radiator.
I will be using 3 inch long screws with nuts to keep the rad attached back there, with the barbs at the top of the rad going into the case above the fan mount. Possibly build a duct for the power supply exhaust too, so the fans on the radiator don't suck in hot air.
If I can get ahold of a camera I will post picture, I won't even waste time with my webcam, it's not even worthy of looking at the case.
