Swordfish45
- Oct 6, 2005
I gave my buddie's computer a major overhaul, i replaced the mobo, cpu, vid card and memory.
When i boot up, it passes the POST,-->
Norton GoBack starts with the prompt "press spacebar to use norton goback",-->
I then see the faintest glint of the Windows loading screen..-->
but right after that, i see the faintest glint of the BSOD-->
Then the computer reboots--^
No other mode of windows works, memtest shows good ram, Knoppix loads without problem, so im ruling out the cpu and mobo as well. Tried different vid cards and keyboards, so im ruling out hardware.
My first order of buisness is to try to replace whatever corrupted file is causing windows to crash. or just repair the installation from the XPpro disk
If i cant figure that out, ill do a fresh install.
Any suggestions?
Any suggestions?
