I've been out of the loop for budget parts for quite some time and would like to put together a decently fast system for my mother. She uses the MS Office suite and surfs the Internet with an occasional dvd watch or cd burn. I want the system to be snappy for her and have some lasting ability (ie no upgrade for awhile). I also would like to include a good LCD screen for her to use, maybe a 22" widescreen if it can fit in the budget.
See above for full details. Mostly web browsing though.
500 + tax + shipping (lower is better, but if I need to up it, I will)
3) Where do you live?
Virginia
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Case, CPU, RAM, PSU, Video card, DVD drive, Mobo, floppy, monitor.
Keyboard and mouse.
6) Will you be overclocking?
No.
Would like a good for text reading 22" LCD.
Soon.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
STABILITY!!!!!!!!!!
10) Do you already have a legit and reusable/transferable OS key/license?
Yes!
I am open to upping the budget if need be and would like to see comparable AMD and Intel system builds.
Thanks to you all!!
Virginia
Keyboard and mouse.
No.
Soon.
STABILITY!!!!!!!!!!
Yes!
Thanks to you all!!
