cyberslag5k
- Jun 29, 2004
Would you guys mind taking a look at this build (updated), and let me know if you see any red flags, missed opportunities, etc.?
Gaming and coding.
About $1,000.
Cincinnati, Ohio
CPU
GPU
Mobo
RAM
PSU
Case
Optical Drive
I already have an SSD, monitor, keyboard, and mouse, and onboard sound is fine.
Intel 330 240GB SSD.
6) Will you be overclocking?
Not really. I might dabble a bit, but I'm not much of an OC'er.
40" 1080p LCD TV.
1-3 days or so.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Just standard use. I don't plan on RAIDing or SLI'ing. They're nice features, because you never know, but I'm not big into multiple GPUs (I Crossfired on my last build when I scored the second GPU cheap, meh), and I don't have much of a need to stripe thanks to the speed of SSD. Mirroring isn't necessary for this box.
Yup. Windows 7 64 bit.
I think it's a pretty straightforward build. I'm open to a GTX 670, but I'd want it closer to $300. The only thing I've found was a PNY with a $40 mail-in rebate for $300, which just looked a bit shady. I couldn't find any reviews on it, either.
I agonized over the 3470 vs a 3570k. The 200MHz didn't really seem worth $40 (I'll be getting it at $150, I live 2 miles from a Microcenter), but I can probably be pursuaded if the performance is really there.
Normally I'm all about the ASUS mobo, but for the price and the rave reviews the Extreme4 is getting, I thought I'd give it a shot. I've also had an ASRock Mobo in the past, and it was fine.
And I know the case is expensive, but I really like it. It's full sized (a strong preference, though not a requirement), and it's got personality. I'd consider a cheaper full or mid, as long as it's not boring (e.g. black, beige, or grey).
I picked the PSU because of its gold efficiency rating and modular capabilities. Other than that, I'm not married to it.
I also wasn't sure what to do about RAM speed. I'm okay upping it if there's a significant performance increase, like if it will pair better with the CPU for non-OC'ing considerations.
Thanks for the help!
Update:
Updated just about everything.
Gaming and coding.
About $1,000.
Cincinnati, Ohio
CPU
GPU
Mobo
RAM
PSU
Case
Optical Drive
40" 1080p LCD TV.
1-3 days or so.
Update:
