Hey all! It's been about 5-6 years since I last built a PC (s939 was my last time if that says anything)... Needless to say, things have changed a lot since then, and I'm starting to poke my head around at the new technology. I know we've already quite a few threads about builds, so I tried to do as much of the legwork as possible, but I still want the advice of the experts! So let's get started.
Here are the initial questions & responses:
Followed by the list of parts that I've thrown together:
MOBO - GIGABYTE GA-EP45-UD3R LGA 775 Intel P45 ATX Intel Motherboard - Retail - $115 ($99 AR)
CPU - Intel Pentium E5200 Wolfdale 2.5GHz LGA 775 65W Dual-Core Processor Model BX80571E5200 - Retail - $82.99
RAM - G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL5D-4GBPQ - Retail - $39.99
GPU - MSI N260GTX-T2D896 OC GeForce GTX 260 896MB 448-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail - $199.99
CASE - Antec Three Hundred Black Steel ATX Mid Tower Computer Case - Retail - $59.95 (I could go with the CM 590 for the same price, not sure which is a better case)
HSF - ARCTIC COOLING Freezer 7 Pro 92mm CPU Cooler - Retail - $26.99
PSU - Antec earthwatts EA430 430W ATX12V v2.0 80 PLUS Certified Active PFC Power Supply - Retail - $69.99
HDD - Seagate Barracuda 7200.11 ST3500320AS 500GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM -$64.99
DVD - LITE-ON 20X DVD±R DVD Burner Black IDE Model DH-20A4P-04 - OEM - $19.99
Subtotal: $679.87 - $15 MIR = $664.87
As you can see, I tried not to skimp anywhere too important. I especially loaded up on a nice MOBO and GPU. Please let me know if the PSU is too underpowered, or if there are other areas where I could cut some corners... If I add monitors into this price, I'm looking at closer to $1k, which really isn't a budget machine!
Mainly what I want this to be able to do is play TF2 reasonably well, and be able to run 3 simultaneous instances of WoW on a single or dual monitor setup. Is the 260 GPU overkill for these requirements? Perhaps I could look at possible downgrades to that.
1) What will you be doing with this PC?
Gaming (WoW, CS 1.6, TF2) will be the primary use for this machine.
$600-700 including all taxes & shipping
3) Where do you live?
Morrisville, NC (Next to Raleigh)
4) What exact parts do you need for that budget?
I need everything. The last PC I built was a s939 rig about 4-5 years ago!
Actually, I do have a copy of x64 Windows XP, so I think Ill probably use that to save $$$ to use on hardware.
5) If reusing any parts, what parts will you be reusing?
Not applicable in my situation!
6) Will you be overclocking?
Heck yea, if it will save me $$$! Im not afraid to OC for some savings
7) What size monitor do you have or plan to have?
Aiming for dual 22 or a single 24 for now. Would like to have a LVM-37w3se. Let's not include these in the budget for my build for now.
No particular timeframe Im not adverse to ordering parts as they go on sale.
9) What features do you need in a motherboard?
Im so out of the loop hardware-wise that I dont even know! Preferably the most feature-rich mobo I can get for the $$$. Im not expecting to run dual-GPUs or anything like that.
OS Options:
I own x64 WinXP.
Vista Ultimate Student Upgrade 64bit from Microsoft - $65 w/o cd, $80 w/ cd
