OutInTheCold
- Nov 10, 2002
To make a long story short, the computer in my sig died and I need to replace the majority of the parts.
In terms of performance, I had no problems with the computer other than the fact that it needed some more RAM. Ideally, I'd like a system with similar performance (though taking into account current components). Meaning, relatively cheap, but also relatively fast. I'll likely OC the computer, though not to a large extent.
I've been out of the loop for a bit so I figured I'd ask for recommendations before I started shopping around. I'll likely need a new processor, motherboard, RAM (2gb), video card, and possibly a new power supply and hard drive.
With regard to AMD vs Intel and ATI vs nVidia, I'm really only concerned with performance and price.
Summary - Need new components. Want something inexpensive with good performance.
Edit: I don't think I'll need SLI either now or in the future. As far as I can tell, it's generally a better idea to simply buy a newer card than it is to add another of your current card. Plus, I don't have the money/need for 2 top of the line cards.
