Citizen _insane
- May 2, 2006
Ok, so I need another renderbox. It's getting a little too tedious for me to render everything on my main box while I want to be tweaking my scene. What I'm looking for is a really cheap motherboard that I can just toss a Q6600 into and have it be stable.
Currently, my 2nd computer is a E6400 w/ 2gb of ram running on an ECS 945GCT-M motherboard that I got on newegg. It cost $30 and has been really stable. Since it only has 2 ram slots, it won't really be any good w/ the quad since I'll be wanting to run 4gb of memory. Anyway, I can use the old C2D to render a couple frames here and there, 10 cores are better than 8.
Can anyone suggest a really cheap (under $50) motherboard that will support the Q6600 (doesn't necessarily have to overclock) and will also support 4gb of RAM? Onboard video would be a plus, but I guess I could move my x1950 from my C2D setup to my quad since the ECS mobo has onboard video.
The only thing I really care about is stability and support for the necessary devices. I'm looking to spend less than $400 on this computer (I already have a case, PSU, fans, optical drive).
edit: Looking at the price of 2gb DDR2 modules, I think that it'll be cheaper to just go with 2x2gb instead of 4x1gb. This means that I'll only be needing 2 ram slots.
