I have Nero Vision... From everything I see online- it should be as easy as adding an AVI file to it and hitting burn.
It works for the most part- however (I have encountered this in the past as well- just don't burn enough to remember how/IF I got around it) I get a blurry line in either/or the bottom or right hand side of the screen.
I even get this in Nero's own little preview thing- so it's Nero that is burning it that way.
I can try any amount of AVIs- it just always does this...
I can play the AVI from my PC in Windows Media Player just perfectly fine.
So I know the AVI is fine- it is just getting converted wrong or something... Any ideas?
Edit- Used ConvertXtoDVD and it *seems* to work on the preview (will have to burn to see), but it's a good waste of time to have to do this if Nero should be able to do it...
