tacosareveryyummy
- Jul 25, 2005
It isn't immediately obvious to me what the error is. I am trying to use OpenMP to parallelize the given loop. Each thread should execute the lines of code up to "run.random_walk()", then update the shared variables n and n_previous which keep track of my current and previous ensemble sizes, and lastly save to a 2x2 vector based on the value of the variable w which is calculated using n/n_previous. The code works and compiles fine sequentially.
Here is the error (Not very elucidating.) :
Here is the loop:
Here is int main():
Code:
mal@ubuntu:~/Desktop/research/modification$ g++ -fopenmp montecarlo.cc
montecarlo.cc: In function int main(int, char**):
montecarlo.cc:114:3: error: invalid controlling predicate
Here is the loop:
Code:
#pragma omp parallel for private(n_e, index, current_time, step, state_vector, step_values, state_vector_p, w) shared(n, n_previous) schedule(dynamic)
for(n_e = 0; n_e < N_e; n_e++)
run.generate_val(total_time/time_step);
for(int i = 0; i < initial_state_size; i++)
{ state_vector.push_back(state_vector_i[i]); }
for(current_time = 0.0; current_time < total_time; current_time = current_time + time_step)
state_vector_p.clear();
for(int k = 0; k < initial_state_size; k++)
{ state_vector_p.push_back(state_vector[k]); }
index = current_time/time_step;
step = step_values[index];
run.random_walk(step);
w = run.weight();
n_previous = n;
n = n + w; //This keeps track of the ensemble size for the normalization energy.
for(int v = 0; v < w; v++)
vector<float> row; //Create an empty row.
for(int o = 0; o < initial_state_size; o++)
{ row.push_back(state_vector[o]); }//Add elements to row.
n_m.push_back(row); //Add row to the vector n_m.
Here is int main():
Code:
int main(int argc, char **argv)
int step = 0, n_e;
float w = 0.0;
float value = 0.0;
float current_time = 0;
int index = 0;
CSMC_solver run;
ifstream infile2;
srand(time(NULL));
//Check for interaction file
if(argc != 2)
cerr << "Usage: " << argv[0] << " <interaction file> " << endl;
return 1;
/*--------Read interaction file---------*/
/*Format of input file assumes
1st line: ensemble size N_e and G
2nd line: number of pair orbitals for |n>
3rd line: s.p. energy of each orbital
all other: n_i i.e. pair occupation numbers
infile2.open(argv[1]);
infile2 >> N_e;
infile2 >> G_ij;
infile2 >> initial_state_size;
infile2 >> value;
epsilon_values.push_back(value);
infile2 >> value;
state_vector_i.push_back(value);
infile2.close();
n = N_e;
w = run.weight();
n_previous = n;
run.Energy();
return 0;
