Shadow2531
- Jun 13, 2003
Can someone post the simplest working example of creating a windows "O.K." message box that doesn't have a taskbar button. It doesn't need to be moved to the tray, just remove the taskbar button.
(Or automatically remove it once it's created)
Google shows examples that don't realy help.
I know you can't do it like the following, but this is an example of what I mean.
MessageBox(NULL,"text", "title", MB_OK,HIDE_TASKBAR_BUTTON);
I should be able to use the title of the message box to manipulate it right?
Thank you.
Thank you.
