Any chance of loading WHS or XP and just getting a feel for the speed of the system. Does it feel like it lags any?It looks like I'm the first lucky knight who bought the VIA NSD7800 and so I'll give you a short review.
From outside the device look great - solid work and no cheap plastic parts. The RAM bay is filled with a 1GB 533Mhz module by via and the Hot-Swap HD bays are looking good. There are enough screws only the CF Slot is a bit tricky to fill, since you have to do it from the front side.
At first boot time a big surprise - a Marvel 81xxx RAID Controller comes up. Rereading the specs but it is not mentioned anywhere. After some experiments I figured out that there are 2 different independent SATA controllers. For the upper 4 HDs it is the via south bridge VT8251 and for the lower 4 it is the Marvel 81xxx one.
Therefore a "hw"-RAID over 8 discs is not possible! But both controllers can create a RAID 0,1 or 5 over their 4 hds.
On the SW side I tried FreeNAS 0.69.1 and Ubuntu and Debian (last releases) but unfortunately the Marvell controller is not recognised and till now I found no driver or kernel patch.
Next step is to try new freeNAS Version where some patches for the familiar VIA Artigo are applied or try to use the recently released 2.6.30 linux kernel where Marvell SATA drivers are included (but atm no time to do this).
At the moment I use the NSD7800 with debian lenny on CF card (using flashybrid) and a md software raid over the upper 4 hds. In the next days I'm going to do some speed testings to look whether the C7 CPU can handle the sw raid issues.
Final comment: If there is any support for the second SATA controller real, good and cheap device but only for Softwareraids.
best regards
minos
Is there a VGA port? How do you hook up a monitor for OS installs and what not?
In my specification with 3 HDs, md SW Raid I got about 28 MB/s
I'm curious about this unit. How is the network performance?
The MAC+PHY in it is remarkably capable for what it is. However, I'm concerned you'd be disk and CPU limited before network limited.
GEOM RAID sucks on those CPUs, so yeah, don't bother. That's what's killing your performance. Don't ask me why; I've been through the code only briefly. Part of the problem is gcc sucking, too. Sigh.
I'm not convinced it's not also a controller woe. CIFS performance should be better. Can you run some single drive non-RAID tests?
Crypto, make sure you have padlock(4) and crypto(4) loaded. padlock_load="YES" in loader.conf needs to be before crypto_load="YES". Also remember that it only accelerates AES, SHA1, SHA256 and RSA. It will sign off on other algos, but that's for ipsec support. If it's not working, let me know, and I can take a look at the code.
EDIT: Yes. I do kernel development on FreeBSD.
He said that he ran the drives as single and then RAID 1
Well, I guess it could be worse, right? I had to limit my CF card to PIO only on my pfsense box.
ATA channel 0:
Master: ad0 SATA revision 2.x
Slave: ad1 SATA revision 2.x
ATA channel 1:
Master: ad2 ATA/ATAPI revision 0
Slave: no device present
Device /dev/ad0 - WDC WD7500AAKS-00RBA0/30.04G30
Device name: ad0
Transfer mode: SATA150
Firmware Rev: 30.04G30
ATA revision: ATA-7
LBA 48: yes
Geometry: 16383 cyls, 16 heads, 63 spt
Capacity: 698GB
SMART Supported: yes
SMART Enabled: yes
APM Supported: no
AAM Supported: yes
AAM Enabled: no
Not really getting any output. Maybe I'm doing it wrong? My FreeBSD experience really isn't all that great.Yeah, but that doesn't tell me anything. SATA and AHCI modes use the same device tree. Only gets funky with VIA RAID. (I'm so not touching that can of worms.)
freenas:~# camcontrol devlist
freenas:~# camcontrol devlist -v
scbus-1 on xpt0 bus 0:
< > at scbus-1 target -1 lun -1 (xpt0)
freenas:~#
I'm redoing my desktop right now, so it will be a little bit before I can do that. Laptop doesn't have an optical drive and I don't feel like doing PXE boot, so, gotta wait just a bit longer.Screw BSD, install some WHS and give us some experience posts.
I'm running 0.7RC1 actually.Ah-ha.
You have to say it's FreeNAS, there's a difference. They use a hacked up kernel. Install 0.7RC and see how that works? (Prior isn't based on 7.2-REL.) Also means I can't give you a patch to run a debug kernel if we need to.
Also, settle down, Ockie. I know for a fact that FreeBSD should be faster than WHS, especially for GELI. I wanna know why it's sucking so hard, and don't have enough reason to justify buying one of these. (Or money at the moment.)
The closest thing would be the 4 bay Chenbro: http://usa.chenbro.com/corporatesite/products_detail.php?sku=79Does anybody know of anything like this, but sold as an empty chassis? I love the form factor but would prefer to use my own mini-itx gear.
