5_against_1
- Jan 11, 2007
Specs usually mention 1080i. If I get a BenQ FP241W monitor and a GeForce 8800 GTX and a HD-DVD drive, can I output 1080p HD-DVDs on my monitor?
1080p is possible but you cannot use a VGA connector to achieve anything greater than 720p (this is my experience). To get 1080i or 1080p you need a DVI to HDMI conversor (a cable, in my case).
I am using the 8800GTX and the HD-3701 LCD TV (yes, 37 inches; but I am visually impaired and this setup is great for me). Using the DVI to HDMI cable, I get great video on the panel using 1920x1080. Using the same display, I can only get 1360x768 on the VGA connector (using the DVI to VGA convertor and a VGA cable).
My research seems to indicate that the 1080 resolution would not be possible without the HDCP capability of the 8800GTX.
This is what I've seen or read about. Where I am wrong, please correct me so others, as well as myself, will have good information to work with. These options are a little vague and descriptions are terse in the documentation and info on the web. Help out with your experiences and knowledge. HTH and TNX
