This is getting really frustrating, so I'm helping someone can help me out. I had surround working without issue on my GTX 260s using the beta drivers. When I upgraded to GTX 460s I had to install the WHQL driver since the beta driver did not support the 460.
Since then, I have not been able to successfully enable surround mode. No matter what I do, once I turn it on, my 3rd display goes into "invalid format" mode. I googled for the issue and found some similar problems, but no solutions and most of those posts were from the beta set.
I've literally spent hours at this and have gotten extremely annoyed. Does anyone have suggestions on what to change? I've removed all extra cards and currently only have the two 460s in the system.
My displays are 2x LG 32LH30 and 1X LG 32LD450 and each are connected with DVI->HDMI cables. It doesn't matter which order I plug the monitors into the card, whichever monitor ends up on the card by itself is the one that will not sync correctly. They all sync fine when using the use all displays mode. The cards are not overclocked. Rest of the system config should be in my sig.
