Concentric
- Oct 15, 2007
Hey people,
I know there are already a number of threads about OCing on this board but none really ask the same questions and I don't want to hijack.
I've been running a new system (sig) for a little while with no issues but was using Corsair Value Select 667 stuff, so got the OCZ Blade LV 9200 kit to see if I could get on with some OCing.
I realise it isn't supposed to be easy, especially on DFIs, but I don't even seem to be able to run the OCZ at stock - I understand this is 1150Mhz 5-5-5-18 at 1.9V?
If I set these options in the BIOS, with no other changes (CPU setting, voltages etc at stock) my MemTest boot CD doesn't even get more than about 5-10 seconds into the first test before the system reboots.
I tried with the Value Select and it happily passes tests.
I've tried upping the DRAM voltage to 2V and increasing the NB by one notch but it didn't seem to have any effect.
What other options could I try?
Could the memory potentially be duff?
Thanks in advance for bothering to read and reply
