CrashGawker
- May 30, 2002
I'm replacing my second generation HTPC (My original one was a K62 like 550mHz system with an AIW 32 about 5 years ago) and thanks to the new software options and new technologies I can finally do a REAL one instead of a windows interface half ass one. Only problem is I'm not having an easy time getting my hardware listing put together. Here's the basic rundown of things I AM sure about.
Software: MythTV under Fedoracore
CPU: AMD nothing under 2.0gHz
RAM: 1GB Corsair XMS
HDD: SATA 250GB 7200 X 3
Cap Cards: A pair of Hauppage PVR-500s
Video out: Nvidia based passive cooled with S-video out and DVI (for when I get s TV with HDMI)
Wireless LAN
Case isn't relevant and I'm going with another Enermax Liberty for the PSU because I love mine.
The problem I'm running into is the obvious preference for the 939 processors and a complete lack of motherboards in 939 that aren't all PCI-Xpress based. I don't WANT to run pci-xpress because the cards are too expensive and too powerful for this application which would be wasting it. Obviously for the above stuff I need two PCI slots for the cap cards and another for the wireless NIC but I also want the ability to upgrade to a higher level sound card in the future if I want which means I'd need 4 PCI slots and an AGP which isn't available in 939 that I can find.
I think my major fault here is that I'm not up on my hardware enough to know what is and what isn't a good brand of motherboard. Can anyone help me out with this?
Wireless LAN
