Mohonri said:All you need are 3300uF Radial-lead aluminum electrolytic caps with a voltage rating equal to or greater than 6.3V.
mouser has plenty
digikey has a bunch, too. On their home page, search for "3300uF" and then select "electrolytic capacitors" on the next page. It has a nice parametric search that comes up.
Jameco also has a parametric search, but I didin't have as much luck with it.
You could try here.magnusvir said:Anyplace I can reliably order capacitors or can anyone hook me up with some?
Did you get the info you needed or shall I move this now?magnusvir said:
