bigstusexy
- Jan 28, 2002
Hello,
I've started to record some things in HD but found its not easy for feasable to play it back so I decided to get a new card to assist. I went form a x1950 AGP to a 4670 PCI Express. The install went well and everything seemd fine no video corruption no glitches or anything.
I tried a HD video, it started to run just perfect! Then my screen went away and the audio stopped. I remoted to it about a minute later and saw that a message about the video driver had stop responding so I restarted.
Short of the long I tried the following:
Media Player Classic
Media Player Classic Home Cenemia
WMP 11
Removing most codecs
Different files.
Different Drivers Cats 9.4, 9.1 and whatever came with the card uninstalling between eachnd multiple reboots for the uninstall and reinstall process.
Voltage Check log
Motherboard BIOS update.
Nothing seemed to work and no problems spotted.
Having come to witts end about this before drastically changing my system I decided to stop and try some games. UT3demo (kept saying I modded it even after a reinstall blah) Need for Speed Most wanted (polly errors, figured it was the game) Quake 4 / Doom 3 All the way up an no issues or problems. UT2004 Super hight and Super fast. I played about 20 minutes of each with no issues save for Most wanted Demo.
I then proceeded to grab another drive install XP SP3 from scratch, added Cats 9.4 all other windows updates WMP 11 Media Player classic and FFDshow lates again and test... Crashed, it was a WMV. Removed FFDshow I think and tried again and crashed.
The errors I get are:
The driver ati2dvag for the display device \Device\Video0 got stuck in an infinite loop
and
ati2dvag.dll ( ati2dvag!_NULL_IMPORT_DESCRIPTOR <PERF> (ati2dvag+0x3a869)+0 )
and
ati2dvag.dll ( ati2dvag!vScaleBltCleanup_R100+89 )
These are the tree I've noticed so far. Any Ideas? i'm going to contact Sapphire later today about this.
Motherboard is a ASRock 4coreduo+Sata2 Bios 2.10
Using DDR2 2GB
PSU TruPower 430
Sapphire Radeon 4670 GDDR4 512
WMP 11
Different files.
Voltage Check log
and
and
Using DDR2 2GB
PSU TruPower 430
