YARDofSTUF
- Jun 19, 2001
I saw that silverstone temjin that flips the board updside down and I like it, but I was wondering if there are other cases that do it too.
Ockie said:Coolermaster stacker 101, Lianli 1200 series or any BTX style case.
which case u gonna get?BronxBartoni said:Sweet titties, thanks guys.
i just ordered an extension cablesonnybobiche said:You could always get some high gauge wire from radio shack and extend the cable yourself. Just be careful.
sprocket said:Here's a SLI-DR board in a TJ06 with an Antec Neopower480 PSU... no problems a bit of modding couldn't handle.
http://img.photobucket.com/albums/v78/clocker/loop1.jpg
I didn't do this because the cabling wouldn't reach...it would.YARDofSTUF said:You cut out the HDD rack part? Where did they go?
I removed all of the stock internals save the crossbrace (which was flipped sideways). The HDDs (in this early pic there is but one...ultimately there were 3) were moved to the top front under two 120mm fans in the roof panel.
Not sure I want to do that, how far away was it from connecting?
I have read just the opposite.Baredor said:I was planning on getting one of the Lian Li V series, despite reading of cable length and PSU fit problems, until I read that the heatpipe on a A8N Premium won't function if the board is upside down.
Blasted physics always ruining my fun.
sprocket said:I have read just the opposite.
Not sure what to believe.
rox1co said:AeroCool Spiral Galaxies bought it for like $92 @ Xoxide - make sure to get a PSU with a long cables (notice the one right down the middle going to the bottom right) everything else is fine, except that cable, not sure wut its called? maybe auxillary cable?
exactly like that Silverstone but not sure which one came out first, they both have a wind tunnel tho i'm not done fixing it yet, i'm not ready to give up on my beautiful case + i wanna take advantage of the wind tunnel
http://img240.imageshack.us/img240/2343/image000076oa.jpg
http://img240.imageshack.us/img240/3453/image000096th.jpg
sprocket said:You'll have to notch the fan body where it interferes with that stupid audio module.
Had to do it in three separate TJ/DFI installs...trust me.
Better yet, 86 the Karajan module and get a PCI sound card.
