snackcakeofd00m
- Jun 16, 2005
Ok, I am uprading my current system and one of the upgrades is memory. My specs will be: Amd athlon 64 3500+ Venice, Biostar 6100-939 mobo, xfx 7800gtx. I am lookng for 2 gigs off at least pc 32000 memory. This brings me to my first question. How come people buy higher than pc3200 memory even if there mobo is rated for the pc 3200? Is it because the memory will be more stable or that you can somw how overclock ur mobo to take the higher speed memory. If it is the latter can someone point me in the direction to a memory overclocking guide. The two choices I am caught between are :
http://www.newegg.com/Product/Product.asp?Item=N82E16820227210
http://www.newegg.com/Product/Product.asp?Item=N82E16820146397
They are both the same price(w/ rebates) So which one do I pick. This memory is going to be in a overclocked rig so the memory must be stable with overclocks.
THNX
THNX
