May 26, 2005 #1 E EnderXC Limp Gawd Joined Oct 20, 2004 Messages 449 Not sure if this goes here but, I have 3 nokia 3100 that I'm thinking about selling, thing is that I want to make sure that all of my info is erased off it. Is there any sure proof way of doing so. Thanks.
May 26, 2005 #2 T TheCzar Limp Gawd Joined Jul 7, 2004 Messages 453 does the manual have anything about a hard reset? perhaps check the nokia site for something like that.
May 28, 2005 #3 X xref Gawd Joined Aug 27, 2004 Messages 553 go to settings and look for "restore factory settings". it should delete all your messages and contacts. if not just try deleting them manually.
May 29, 2005 #4 T TGA Gawd Joined Jun 26, 2004 Messages 825 The 3100 is a GSM phone if it is the one I am thinking of. I believe all personal data is stored on the SIM card. So just be sure to remove it.
May 29, 2005 #5 T TheCzar Limp Gawd Joined Jul 7, 2004 Messages 453 not necessarily...you have the option of storing on the sim, but by default most store in the phone because it has better access times and more space.
